AUDIO TECHNICA AT-LP60BK-BT FULLY AUTOMATIC BLUETOOTH WIRELESS BELT-DRIVE STEREO
Audio Technica AT-LP60BK-BT Fully Automatic Bluetooth Wireless Belt-Drive Stereo Type: Case Accessory Type: Belt drive turntable, fully automatic System Requirement: Motor – DC servo-controlled Input Impedance: Phono Pre-Amp Gain – 36 dB nominal, RIAA equalized Output Impedance: Pre-amp “PHONO�: 2.5 mV nominal at 1 kHz, 5 cm/sec / Pre-amp “LINE� 150 mV nominal at 1 kHz, 5 cm/sec Turntable Speed: 33-1/3 RPM, 45 RPM Signal-to-Noise Ratio: >50 dB (DIN-B) Power Supply: 120V AC, 60 Hz, 3W
Price: 179.00
