AUDIO-TECHNICA AT-LP1240-USB PROFESSIONAL DJ DIRECT-DRIVE TURNTABLE - USB AND ANALOG
Audio-Technica AT-LP1240-USB Professional DJ Direct-Drive Turntable (USB & Analog) Specification: Speeds: 33-1/3 RPM, 45 RPM, 78 RPM Starting Torque: >4.5 kgf.cm Wow and Flutter: 55 dB (DIN-B) Output Level - Pre-amp "PHONO": 2.5 mV nominal at 1 kHz, 5 cm/sec (HP-4005) - Pre-amp "LINE": 150 mV nominal at 1 kHz, 5 cm/sec (HP-4005) Dimension: 17.72" x 6.56" x 13.90" (450mm x 166.5mm x 353mm) Weight: 27.6 lbs. (12.5 kg)
Price: 449.00
