10 700 WATT POWERED TWO-WAY SPEAKER WITH MP3 - USB - SD - BLUETOOTH STREAMING AND RECORD FUNCTION W - REMOTE CONTROL
10'' 700 Watt Powered Two-Way Speaker With MP3/USB/SD/Bluetooth Streaming & Record Function w/Remote Control Type: LED Indicator Specification: Bluetooth Music Streaming Ability Works with Bluetooth Compatible Phones, MP3 Players, Tablets, etc. 10'' Woofer and Compression Driver with 1'' Titanium Diaphragm Full Featured 3-Channel Mixer XLR and 1/4'' Mic Inputs RCA Line Input XLR and 1/4''Line Output Master Volume, Treble, and Bass Controls 3.5mm Aux-In Compatible With All Digital Music Players, Including iPhones Record Your Music to USB Flash or SD Memory Card Play Music Files via USB Flash or SD Memory Card Includes Remote Control Sensitivity: 98dB Frequency: 46Hz-3kHz Voice Coil: 50mm, 2inch Magnet: 40oz. 134mm Impedence: 8 Ohm Sensitivity: 110dB/m.w Frequency Range: 600Hz-20kHz Diaphragm Material: Titanium Power Output: 350 Watt RMS, 700 Watt peak Crossover Frequency: 2.2kHz 110/220 Voltage Selectable Integrated 35mm Speaker Stand Mount Sold ...
Price: 148.99
